sandcobra164
- 295
- 83
- Leesburg, GA
I'm getting ready to do my spring maintenance on the truck and have just a few questions. I'm doing everything but the hard lines on the brakes and have NOS parts in hand. I've got oil leaking out of the output shaft on the trans and input shaft on the t-case. Does anyone have seals available for them. I've also got an oil leak coming from the trans input but I've been told that's normal and not to worry about the oil it's leaking out of the bellhousing hole. Is there a seal on the input / output or not. The trans was a little higher than 1 knuckle before it drove to the rally (180 miles one way) and now it has some wet spot's) (drip's don't drop/Class 2) since coming back and the oil level is very slightly lower and the breather's are fine. IF that's normal, than thanks for the replies, IF not, let me know what needs to be done to get this truck ready for inspection.
Thanks,
Joseph
Thanks,
Joseph
