84cucv1ton
- 0
- 36
- New Jersey
its a 87 m1028. 30k on it. all stock other then the doghead relay. had some creative wiring done by the military. took it all off. cleaned ever ground and connection front to back. all seemed ok for a while. 2 new batteries. 950cca. would hit the button for the gp for 15 seconds. now that its really cold. been hard to start. was cranking it today. relay stuck open. pulled the - of the front battery. it stopped cranking about 20 seconds later 3 blue wires burnt up by the gp relay. 1 wire goes over to the power block. other 2 join and go to the block to the left of the gp relay. I have a new relay on order. wiring is not my stong point. where should I start with this?? thanks a lot.
