The Diode Trio (I think) went bad in my gen2 (m1009). I replaced it and returned the alternator to its nest. The rear battery was almost dead and did not have enough juice to turn the engine over. So I went to jump start it with another cucv (m100. I think this is where I went wrong. I connected one side of the cables to the positive terminal on the rear battery, and the other side to the negative terminal on the forward battery on both vehicles. I hopped in and went to start the 09 and got a rapid clicking sound that was very audible in the cab and from outside under the hood. The engine also turned a little, but not all the way over. It sort of "vibrated around" instead of turning over, almost as if the started was hooked up to AC instead of DC. I reconnected the cables, connecting just the rear battery, it turned over slowly, but everything sounded normal. However, now I have no accessories at all in the 09, NONE. No horn, no lights, no blinkers, nothing but the start up dash lights, glow plug system, and starting system. Any ideas on what I broke/burned/fried? Is there a main fuse or something for the accessories?
