cshaw07
- 0
- 6
- e. palestine ohio
when my relay went bad all i had was a big pair of channel locks..... i grabbed the top and bottom of the relay with them to jump it, did that for 3 days until my new relay came ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Yea, would love to see the pictures of thatHI GUY I agree with matt,about starting fluid but if you do try it make SURE you crank the engine as you give it a small amount. To mutch then cranking it can cause what I saw at a cal guard shop once,a dump trk that someone did that then when they cranked it over it blew the heads off the block.![]()
I agree you don't need to use starting fluid but in a pinch you can get your truck going. It's not a replacement for the glow plugs. This has been done thousands of times over and over with these trucks and other vehicles. If the stuff was so bad you would not see it for sale every where. There would be an almost daily report of engines exploding. Like all things safe in moderation.That's good advice for the newbe.
I respect your opinion and experience, but I would not encourage the use of ether to a newbe or anyone new to diesel engines. I have been operating and repairing heavy equipment for thirty years now, and have reluctantly used starting fluid as a last resort to get a key piece of equipment started so it's far from my first rodeo. The use of starting fluid in my trade is allways met with raised eyebrows by true professionals. We don't do it unless we absolutely have to. Apparently the OP took Dogheads advice and got his truck started without the use of starting fluid.I agree you don't need to use starting fluid but in a pinch you can get your truck going. It's not a replacement for the glow plugs. This has been done thousands of times over and over with these trucks and other vehicles. If the stuff was so bad you would not see it for sale every where. There would be an almost daily report of engines exploding. Like all things safe in moderation.
I have owned one of just about every us military vehicle available from motorcycles to tanks. Its not my first rodeo.
The bigger trucks even have ether canisters mounted in the engine compartment and operated from the cab for cold starts.
I got the glow plugs working using dogheads suggestion thanks to all. Without this site i would have been totally screwed. On the down side i couldnt get it to start, after going through an entire checklist i cracked an injector line and found my ip is just dribbling fuel. Anyone have an extra ip for sale around clarksville tn?
