Strange noise on m35a2
Bobweb
163
Morganton, Georgia
greetings everyone,
I went out to start the deuce this morning and when I flipped the battery switch, I heard a loud humming noise. I immediately shut off the battery switch and waited a few mins and tried it again. Same thing happened. I have a feeling it’s either the starter solenoid locking up or the fuel pump burning up but I am not sure. Anyone ever had this experience? Where should I start to trouble shoot?
Ps it ran fine yesterday for a 4 hour ride no problems and no noise
glcaines
2,548
Hiawassee, Georgia
I would have someone else turn the master on momentarily while you diagnose where the noise is coming from. That way, your helper can shut the master off immediately if needed before significant damage.
SCSG-G4
PSVB 3003
3,324
Lexington, South Carolina
Look in the tank and make sure it has fuel, then using 'soldier B' to flip the switch on, stand by the tank and see if that is where the noise is from. If not, try other places.
Bobweb
163
Morganton, Georgia
Could it be that after driving off road for a while, I knocked the low air buzzer into working? I’ve never heard this noise before but it most definitely could be that low air alarm if it hums loudly. I was alarmed because it sounds like when a fan motor or other small motor is shorting out.
it def has fuel, just filled the tank.
im out in the woods today but when I get home I’ll have someone help me. Thanks for the suggestions fellas, I’ll report back.
Bobweb
163
Morganton, Georgia
Could be. I just turned the switch on. Could hear fuel pump activated, then 5 seconds later intermittent hum sound. Could be low air alarm that started to work. We took a extremely bumpy off-road ride through the picayune where I work and then a day later this sound started. Maybe I am bounce-fixing my deuce
doghead
4 Star General /Moderator
1,176
NY
Unplug the wire on the low air alarm and see if the noise stops. Or, build or charge with air pressure and see if it stops.
Bobweb
163
Morganton, Georgia
yep, it was the alarm. I’m new to the deuce and didn’t even realize it had a low air alarm. Mine sounds pretty rough but I must have knocked it into working driving around the trails. Thanks for all the suggestions everyone!
