Stuff on my truck
Barrman
2,000
Giddings, Texas
My m35 has a few things I am not sure I have seen before on other trucks. This is on the passenger side. What is the hollow tube the mirror is bolted to?
When did this style of mirror and bracket stop being used?
Then I have the cab mounted rear facing spot light and hard top. The spot light has a huge base that basically wraps around the rear corner of the cab. It seems way to big for just a light mount. Did something else ever get put in the mount?
Then there is the hard top. It looks real well done, but I don't think it is in anyway stock. It had 70 stainless steel screws holding it on. I pulled it off after I took the picture. The top of the windshield frame had to have the canvas top groove removed for this top to fit by the way.
Once I got the top off, I realized the entire top of my windshield frame is rotted away. I also couldn't get the top bow out of the cab. Is there a secret to it? I can't see or feel any bolts, collars or welds so I have just been spraying penetrating oil into it for a day now.
Thanks!
mangus580
282
Western NY
The tube the mirror is bolted to, is the mount for a gun ring. They all have it.
I like the mount for the light!! would like to see some more pics of it...
westfolk
157
PA
How about that box(bed)? Looks like a dropside to me. Would that make it a 195? M35A2C like my Reo?
DDoyle
82
West Tennessee
The light looks like the one used on Bridge Trucks, pipeline trucks, and maybe bolster trucks. Definately not stock for the M35 - the bed is also an add-on - dropsides did not come out until gas engines were gone. Fuel tank looks like a replacement from a Multifuel as well. The cab top is also non-military.
I've gotta dig a bit on the rear view mirror question.
HTH,
David
doghead
4 Star General /Moderator
1,185
NY
The hood hold down hooks are inverted from the way mine are mounted.
houdel
10
Chase, MI
In addition to a MG ring mount, the tube on the passenger side is also used to mount convoy flags. All Deuces (at least all I have seen) have the tube mount on the passenger side. Don't lose any sleep over it!
As best as I can recall, your type of mirror dates from the early 70s and before. I seem to recall driving NA Deuces in the early 70s with that type of mirror. Not sure when the "West Coast" style mirror was adopted, it was after my service time!
1,138
If you don't want that spotlight mount, pm me a few pics of it, we might be able to strike a deal.
Barrman
2,000
Giddings, Texas
Thanks for the info on the passenger mirror mount. I do need two of the mirrors themselves, but since they look exactly the same as my M715 mirrors and I know where some of them are, I will hold of spending any money on them for now.
Both of my trucks have the hood latches inverted like that. I don't know what year the other one is yet. This one is a 1951.
This one came with a spare M35A2C cab in the back. I assume the bed came from the same truck. What difference is there between the mulitfuel bed and the gasser bed? If you look in my first picture, you can see the exhaust pipe sticking out above the rear tires. The pipe has a flanged connection just inside tires. How did the fording stack attach to the bed?
It looks close enough to try, but will the A2C windshield frame bolt right onto my cab?
Any suggestions on how to pull the top bow out of the cab?
Thanks again.
ken
26
Houston Texas
Yep the other windshield frame will fit they are the same. The top looks like a forrestery service top. I've seen alot of thes tops in east texas on forrestery service trucks. Alot of M715's got the ugly FS tops too.
Barrman
2,000
Giddings, Texas
The truck has a company in Mass (The Mitre Corp) name painted on both doors. I figured they are the ones that made and added the top. This truck also has a battery box under the passenger seat with a water heated plate for the batteries to sit on. My other truck has a gas fired water heater still in the box sitting in the cab. I figured the top was made for cold weather.
I know all about the forest service tops Ken. Here is my M715 with the top all painted. I added the hook on top to make pulling it off a lot easier. I put a $49.99 Harbor Freight 120 V winch on the ceiling of my shop and just back the truck in, hook up, unbolt 7 bolts and I have a convertible. This top was held on by 146 rivets that I had to drill out and then weld up the holes on. The M35 only had 70 screws. A lot easier.
Ken, aren't you the one I talked to on the phone a week or so ago from Spring? If so, you have now seen what all I need, don't scrap stuff that will fit please.
Banshee365
14
Ocala, FL
Yea that hardtop is definitely repro. Truck needs work but looks like it has alot of character, not many trucks like that left around that are in somewhat good shape.
BTW,anyone know where to pickup some of those screw type clamps that hold the drop sides up? The ones on my bed are rusted and I'd like to find some replacements. I saw a brand new 8 ton or something Oshkosh cargo truck at the airport a few months back and it uses the exact same clamps.
-Kelly
ken
26
Houston Texas
Sorry barman. That wasen't me on the phone. And yep thats a FS top on your M715 all right. Let me know what you need. I may have some stuff in my pile you can use.
67Beast
539
Silver Lake Sand Dunes MI.
As far as the cab bow goes Tim, it is not like a 715 bow. On a deuce, only the center section comes off. When you pull off the window surrounds, the corners of the bows stay with it and only the center bar comes loose.
gimpyrobb
dumpsterlandingfromorbit!
27,786
770
Cincy Ohio
Tim, mine's a 73 and has those mirrors. I do have the hood-lift-handle though. Also Tim, the m35a2c cab came with the drop side bed. That "C" is what indicates drop side.
FreightTrain
Banned
2,730
13
Gadsden,Al
If that is a soft top frame and not welded in place it just pulls straight up.Nothing hold it on except gravity.There is a round hole in the cab corner it fits into.You might have to inch it a little at a time on each side before you get it off.The pole going into the cab corner is about 6-9" long.Also,considering the condition of the windshild frame,you might have to brake out a BFH and give it a little help.
