Two group 31AGMs from batteries plus. $265 each. 4yr replacement. I bought them cause of the warranty. I run just two in most of my big stuff.1078 is box stock and warmly resides in Florida .... thoughts ?
Exact specifications are normally in the TM'sand this 24v positive terminal was melted in the opposite side...where can I find a replacement cable (complete) or at least the correct terminal end?View attachment 852003
and that's the good side..the other side is melted away as if the autistic third grade IQ Army mechanic used that terminal end as an arc welder.Exact specifications are normally in the TM's
That is one ugly picture of battery terminal you got there.
Say what vehical it is so You may get help, It aint difficult, but that is ugly.
I found the part in 24P... listed under "yeah good luck"...M1078 TM's
Listed below are a number of the TM's for the M1078 trucks. To save them to your computer, right click, select "save as" m1078_TM 9-2320-365-10.pdf TM 9-2320-365-10 for the M1078 series trucks. m1078_TM 9-2320-365-20-1.pdf TM 9-2320-365-20-1 for the M1078 series trucks. m1078_TM...www.steelsoldiers.com
Two batteries in series… Take a battery(lets call it battery #1) and connect the ground lead to the - terminal. Take a second battery(battery #2) and connect a jumper cable from the + terminal of #1 to the - terminal of #2. Connect the 12v lead at either end of the jumper. the last + terminal on #2 is your 24V so connect the 24v lead there. If you have a nato plug, connect the leads to the same terminals as ground and 24V. Gnd goes to the outer ring in the nato +24 goes to the center post in the nato plug…Can anyone provide a wiring diagram for a 2 battery set up….thanks all 1078A0
ok, ok, here is a picture
Exactly! I actually forgot to draw it on mine also. One goes directly to the starter and the other goes to the polarity protection box and alt…Good job with the video there.
fyi: the A0 trucks all have the two cables on the 24v post. Later A1 and A1R trucks *sometimes* have only one. I only mention it because anytime I post that schematic someone will say "there's only one cable on the 24v post".
I have an M923 and have been using the biggest batter W-mart sells for the Dodge diesels. Sorry don't remember the group number and can't go look now. But they are around 120 and have a full 3 year replacement warranty. When I first got the truck, went with new Interstate 6TL's, about 240 each and 1 year warranty. Of course one died at 1 yr 3 months. We have installed the W-Mart batteries in 5 trucks now with no problems.1078 is box stock and warmly resides in Florida .... thoughts/recommendations?
The 260a is awesome but keep in mind that the 12v side is 140a. It's always a battery on the 12v side (either with quads or duals) that's getting sucked on by the "vampiric drain". If you have a master disconnect, that will solve the issue. The only other surefire fix is a 12v charger (simply on the 12v side battery) and a battery equalizer.after much research and pestering the electrical gurus that frequent this forum and even though I have a "upgraded" Niehoff 260 amp alternator, which by all accounts can easily handle a 4 6TL battery configuration, I like the simplicity as well as quite possibly reducing some "strain" on the alternator.... plus one of my 6TLs went flat the other day, the other 3 are well within voltage and load specs....soooo there you have it... thoughts anyone ?
I have a battery ground disconnect already installed....the battery tender to the right is a 24v (2.5amp) that I was using in the 4 6TL battery set up.... I imagine it will be aok to use with my 2 6TL battery set up..The 260a is awesome but keep in mind that the 12v side is 140a. It's always a battery on the 12v side (either with quads or duals) that's getting sucked on by the "vampiric drain". If you have a master disconnect, that will solve the issue. The only other surefire fix is a 12v charger (simply on the 12v side battery) and a battery equalizer.
My end game is both but I haven't decided where to mount my Bussmann EQ (my thinking is the battery box space is still best used for batteries especially given that the charger and eq will fit in a relatively small compartment).
