surge braks bushings?
wanabecruisen
Hamburg, AR
Need some help from the experts! I'm trying to revive my m416 surge brakes and found the replacement master cylinder I needed but in trying to free up the mechinism I discovered several worn bushings in the pivot assembly. No luck finding these odd size bushings locally. Anybody have a source for them? Am I going to have to make some?
2ndchance
Glendale, AZ
... I'm trying to revive my m416 surge brakes and found the replacement master cylinder...
Could you share with me where you found the replacement master cylinder for your M416-A1? I'm in the process of restoring an A1, as well. It looks like I need some new wheel cylinders, too!
Thanks in advance!
2ndchance
Glendale, AZ
Wow.. no response, so I took the chance and ordered the parts. Luckily everything fit.
The nylon bushing can be found at eTrailer and Croft Trailer. They are listed one of two ways. Toledo Actuator Nylon Bushings OR Balcrank Nylon Bushings. Either way, their part number: 1745. CroftTrailer.com has the best price.
1745 --- Balcrank Toledo Actuator Nylon Bearings - Croft Trailer Supply
The replacement master cylinder did turn out to be one that fit 49'-53' CJ-3A. Kaiser Willy had them for $50. Part number: 805223. It was a perfect fit.
Master Cylinders - Master Brake Cylinder <br>Fits 46-66 Jeep & Willys
The shock dampener that goes into the surge housing is also made by Toledo/Balcrank. Part number: 1844-2. Sells for $55-$60. Again, CroftTrailer.com had the best price.
1844-2 --- Balcrank Toledo Actuator Damper Shock - Croft Trailer Supply
All of these were an exact fit for my M416A1. I found these when I noticed that on top of my surge mechanism, had the Toledo Hydro-Act logo stamped on it.
