Have you ever been over to Langtry Tx ?
What happens there?
Not sure about the LS motors but weren't they made for pickups ?
I know back when I joined SS there was a member from Indiana who put a Ford 429 in a deuce ,but unsure if it was a 429 car motor or truck motor .
They shared a lot of parts but the truck motors ( f600 ect) had heavier blocks . Ford did the same with FE and FT motors ( 360,361/390,391).
For a parade truck it will probably be ,to use it as a 5 ton was designed for it may have a shorter life .
They're used in the GM pick-ups and full-size vans.
Here's a comparison between the
L96 Vortec 6.0L (for greater than 10000 lb GVWR trucks, or is it GCWR?) and the Continental R6602 (From TM9-2320-211-20):
Attribute | GM L96 Vortec 6.0L Small Block V8 | GM L18 Vortec 8.1 Big Block V8 | Continental R6602 Inline-6 |
Horsepower | 322 @ 4400 RPM | 320 @ 4200 RPM | 224 @ 2800 RPM |
Compression Ratio | 9.7:1 | 9.1:1 | 6.4:1 |
Torque (lb-ft) | 380 @ 4200 RPM | 440 @ 3200 RPM | 425 @ 2000 RPM |
Governed or Max Speed (RPM) | 6000 | 5000 | 2800 with no load |
(Added the
8.1L Vortec motor as mentioned by
@Jbulach )
It turns out that I mis-remembered the torque of the LS motor being equal or better than the old Continental, about 11% less torque. However, the LS motor develops about 44% more horsepower. Is it worth the trade-off? I'm thinking not.
Also, something would have to be done about the gearing on the truck to accommodate the LS motor's higher RPMs needed for doing
anything. At least the motor won't be red-lining to get the spec, but it will be spinning a lot faster than the Continental. I'd like to think that modern motor technology can withstand such high RPMs continuously compared to the older motors, but I only know enough about motor design to cause trouble
