Swapping a gas 350 into a M1009
Alexander
Omaha, NE
Hi All,
I have a 85 M1009 (TH400 and NP208) with about 35000 miles and no engine. The diesel engine was pulled before I got it. I want to keep the stock TH400/NP208 in the unit.
I bought an 88/89 350 blazer with a 700r4 and NP241(I think) to use as an organ donor. The electrical, cooling, and exhaust conversions are something within my knowledge base, but I know nothing about what I’ll have to do about the transmission/torque converter issues.
Can anyone tell me what I’m getting into. Can I use the converter from the M1009? Will there be some vacuum modulator issues? Can I use the original radiator with the transmission oil cooler? Any comments would be appreciated.
Thanks,
Alex
mangus580
282
Western NY
Drop it in :) The TH400 should bolt right up, and work perfect. The radiator might work, not sure on how things will line up.
gt1009
st.charles,IL
seems like a good idea to me, what with the price of diesel now, and as such an easy drop in it should give you a sufficient amount of power
bugmann
temecula ca
Hi All,
Thanks,
Alex
the radiator for a gas 350 etc will be 1 1/2' 6.2 radiator hoses are wider
M35fan
3,992
Arab, Alabama
OP probably won't see this since he was last seen in 2011. But that old 350 is probably still running, somewhere.
Feet: ' Inches: ".
Sorry, it's a pet peeve of mine.
Otherwise, the info is still relevant for someone doing this swap.
