Switches
ijchan223
MS
I am having some issues with a few M819s wrecker wiring. I am able to start the truck but the switch can not kill the engine.
I am unsure if the switch has been fooled with before so i do not know if it is installed correctly
m16ty
211
Dickson,TN
It could also be the the fuel shutoff on the PT pump. Also make sure somebody hasn't fooled with the shutoff override screw. It should be screwed all the way out for the electric shutoff to work.
If you still have power on the wire going to the fuel shutoff with the switch in the off position, It's probably your control box.
ijchan223
MS
Happen to have a image of the switch, i do not recall seeing a solenoid around the fuel pump area.
( i can be looking too hard for it)
73m819
320
gainesville, ga.
Your fuel shut off, how are you shuting down now
The -10 shows the thumb screw
m16ty
211
Dickson,TN
Find your PT pump (injector pump). On the top of the pump there will be a solenoid with a wire attached to it. In front of the solenoid will be the manual shut off screw. It's a thumb screw but you can also use a stubby flat head screwdriver to turn it.
ijchan223
MS
I am currently shutting it down with the emergency fuel cutoff ( a mechanical valve). I may just be over looking the solenoid aua. Thanks for all the help
ijchan223
MS
Thankyou very much, it turns out that you are correct, the solenoid bypass was engaged. It turns out that I wasn't looking hard enough for the solenoid, on a few of the other trucks the solenoid sticks above the PT pump but this one was hidden behind a bracket that holds the cable for the throttle
