phat6
- 1
- 3
- Jasper, IN
Talk about sticker shock--ever priced out changing an M925A2 over to full synthetic, top-to-bottom, front-to-rear? Also have not been able to find a consolidated run-down on the fluids, but this is what I gather from the bits and pieces. Looks like I could go all Mobil 1 or all Royal Purple:
~$2k . . . like zoiks, Scoob!
- Engine Oil
- 20 Quarts
- Mobil 1 0W-30 - $5/Quart in 5 Quart Size (Wal-Mart)
- Update: Mobil 1 5W-40 Turbo Diesel only one that meets API CJ-4
- Mobil 1 Extended Performance 5W-30 - $5.50/Quart in 5 Quart Size (Wal-Mart)
- Update: Does Not Meet API CJ-4
- Royal Purple HPS 5W-30, 5 gallon, PN: 35530 - $163.40 (Jegs)
- Update: Royal Purple 15W-40 only one that meets API CJ-4
- Update: Look like I am going with Mobil 1 5W-40 Turbo Diesel
- Transmission
- Total Capacity: 25 Quarts
- Drain & Refill: 19 Quarts
- Mobil 1 Synthetic ATF - $11/Quart
- Royal Purple Max ATF, 5 gallon, PN: 05320 - $263.79 (Jegs)
- Transfer Case
- 6.5 Quarts
- Mobil 1 75W-90 - $11/Quart
- Royal Purple Max Gear 75W-90, 5 gallon, PN: 05300 - $287.38 (Jegs)
- Differentials
- 12 Quarts (each), so 36 Quarts
- Mobil 1 75W-90
- Power Steering Fluid
- 3 Quarts
- Hydraulic System
- 32 Quarts
- Winch Gear Case
- 2.6 Pints
- Mobil 1 75W-90
- Grease Points / Zerks
- Mobil 1 Synthetic Grease - $7/tube
- Royal Purple Ultra-Performance Grease - $9/tube
- Coolant
- 40 Quarts
- Evans Heavy Duty Waterless Coolant - $48/Gallon
- Grand Total: (Mobil 1 / Royal Purple)
- Motor Oil: 20 quarts - $100 / $164
- ATF: 60 Quarts - $660 / $792
- Gear Oil: 44 Quarts - $484 / $632
- Grease: 5 Tubes (Guessing) - $35 / $45
- Mobil 1 = $1,279, Royal Purple = $1,633
- Evans Coolant = $384
