tatra-kolos
- 0
- 0
- Boynton Beach, FL
I purchased this vehicle 2 years ago from a guy in Denmark who had been performing a frame-off restoration, and the project got too big and took too long - My wife, daughter and I travelled to Denmark and visited with Lars and his wfe (wonderful people, wonderful country), and since then I have been planning on bringing the truck back to the States. My original contact with Lars was through the internet - he had a website documenting his project. I got lucky.How did you go about finding yours in Europe if you dont mind me asking.
Thanks to "cranetruck" for posting the picture of the chassis. I believe that this picture is a cut-away CAD drawing of a late-model T-815 civilian chassis (Note the central airbag helper springs, and larger spacing between #2 and #3 axles, and no central winch). I have to say that all of the information and inspections I have made of various Tatras lead me to have a great deal of respect for their engineering. Too bad the economic idiocy of the communist leadership did not allow them to flourish to their potential!
I have seriously considered and investigated mounting a towed trailer (sans wheels and axles) on the tray bed, as the easiest and most economical method. In fact there are a couple on the market with rear slide-outs which would be very suitable. I would prefer units with double bunks at the front, so I could cut a passageway from the existing truck cab into the travel trailer portion (would need a flexible coupling - a-la some pasenger train connections). However I have serious reservations about the durability of a travel-trailer for off-road use. Their frames are built very lightly to insure easy towability, and I believe that mounted on the back of a Tatra, the off-road swaying motions will result in twisting and torquing which the travel trailer will not survive for long. I may still wind up doing this since all of the utilities (water, sewer, air-conditioning, power other than generator, etc.) have already been completed, and the economics are very attractive. I will wait to get the truck to Florida before committing. I just looked at the website of the guy with the T-815. He is undertaking a huge project there.
I certainly agree that messing with the dirveline which is encased in the central chassis tube would be a very BAD idea. I am working from my photos of when my truck was under frame-off restoration. (I am attaching some below) My idea was to interpose a 2 speed overdrive/underdrive transmission in the shaft leading from the engine bell-housing to the input of the transmission/transfer case. I do not know if this will be possible or not, but the end result would effectively decrease engine rpm while increasing rpm of driveline. I would absolutely agree with you that the tire height could not be effectively increased. (However, I have seen pictures of T-815's which were being promoted to Middle Eastern militaries, with tires with dramatically increased widths - probably not necessary for our applications though) I am assuming that the maximum road speed is engine RPM limited due to optimization of the drivetrain for off-road. I may be overlooking some other limitation however. Since my intended use will be mostly off-road, the speed limitation will not be prohibitive, but higher road speeds would obviously be highly beneficial. I was not aware that the entire driveline was in an oil-bath. I had thought that the chassis tube was under positive air pressure. I wonder how they deal with friction and oil foaming from the rotation of all those shafts immersed in oil? Well, this is going to be a learning experience.As far as adding the overdrive the drivetrain on a tatra is like nothing I have ever seen, all the drivelines ,axles etc are incased in a huge tube emersed with oil (for protection) so just adding gearboxes etc would be a huge challenge if not close to impossible.
Thanks again.
