Technical Manual Request
Coug
4,356
Olympia/WA
I don't think there is a -20.
I think they went straight to a -24-1 and -24-2 to go with the -24P parts manual.
The only 9-2320-387-20 I could find is an MWO, not a TM
juanprado
2,922
Metairie/La (N'awlins)
What model of truck?
This might be what you are looking for that I posted:
Coug
4,356
Olympia/WA
The M1123 you need the TM 9-2320-280-XX manuals to work on it, as it's an A2 truck. The -387 manuals are for the ECV/REV series of truck.
nairb
110
33
Liberty Hill, TX
Mine has a rebuild date of 2009 and a red dot installed, maybe thats why it has the different TM for the serpentine belt?
Coug
4,356
Olympia/WA
not likely.
That's the generic sticker for all pre 196900 serial number serpentine belt systems whether they have Red Dot aircon or just a pulley blank in that spot. Well, other than the fact that it lists a TM that isn't used for any of the HMMWVs as far as I can tell.
The Red Dot aircon doesn't change anything about the belt routing, only that the belt is about 10 inches longer and routed the exact same. (Or so I think. There might have been slightly different routing for one of the idler pulleys on top that it went over both of them, rather than over one then under the other, but at this point just run it like the sticker shows and call it good)
Just ignore the TM listed on the sticker and use the standard manuals.
nairb
110
33
Liberty Hill, TX
Thanks! That’s good info about the ac, I was looking for this because I’m planning on removing all the ac components. If anyone needs red dot components in Texas let me know.
Guyfang
24,095
Burgkunstadt, Germany
Look in TM 9-2320-378-24-1
3-81. Serpentine Drivebelt Maintenance (Serial Numbers 196900 and Below) 3-142
3-81.1. Serpentine Drivebelt Maintenance (Serial Numbers 196901 and Above) 3-142.4
Please let us know if this helps.
Guyfang
24,095
Coug is correct. Its the TM 9-2320-280-24-1. I just went back to look again. I had too many TM's open at one time. When looking for what truck is in what TM, its always best to have the Model number, AND the NSN. Then simply look for that on the front cover. My mistake.
