RandyMcB
- 3
- 0
- Columbia Pa
I have a 395 tire that I am using on one of Zack's ( donkeydonk) wheels. Which I believe are 5 ton with deuce centers welded in. The tire has a pin hole in the side wall and the tire shop is concerned about trying to patch a side wall. We may try to patch it and run a tube, but because of the size of the valve stem hole in the wheel we are not sure if the reg radial tubes will work.
Any one ever succesfully repair a sidewall? And exactly what tube size and flap size should I use with this tire wheel combo ( 395/85/r20 and a 10x 20 wheel ) I have read many different threads but none I came accross dealt with this issue, so I appoligize if this is a redundant thread.
