- 9,604
- 1,493
- 113
- mid- michigan
thin wire retaianing on inside of hub try pushing in on hublock it won't move much take a small screw driver between the lockout and hub scrape around inside hub you should feel the wire it will spin in the hub it rides in a slot you have to keep it from spinning and pry one end out and work it out they can be stubborn some times you also need to the snap ring off end of axel if you can't get pm your phone # might be easier to explain that way
gary
gary
