Trailer Connections M871
rumplecat
221
North West Arkansas
Does the M871 lowbed trailer have both military and civilian electrical and brake hook ups like my new to me M127 does?
James
BKubu
1,178
Gaithersburg, MD
James, I know that GL calls the M871 a lowbed trailer, but the M870 is actually the lowbed. The M871 is like an M127 as far as I can tell. I don't know the answer to your question, though.
jasonjc
290
Gravette Ar.
The TM for the M871A2 shows both the military plug for lights and a civi plug. Not shure on the M871 or M871A1. The brake are the same for all.
As for "lowbed" if you can call 55" low:roll:
The TM for the M871A2 is TM 9-2330-386-14&P
I do not know the TM for the M871 or M871A1
There is also a warning in the TM
NOT to use the M871A2 with the M52, M52A1 or M51A2 tractors.
Hope this helps
NDT
6,631
Camp Wood/LC, TX
M871 has both the mil and civilian hookup. Why, Rumplecat, would you be needing this info? ;-) Trailboss (I would imagine) and I have a bad case of buyer's remorse for jumping on the earlier trailers
rumplecat
221
North West Arkansas
Beware of Snipers
I am in the same boat on the bolster trailers that were in Little Rock, I paid double what they went for in Hooks. I expect to be sniped in the last 15 minutes this time!
James
Trailboss
139
Norwood LA
Yeah, prices are all over the place, depending on where you are, how many are selling, and when the sale is. In LA in the same like-new condition, they went from 3600-6000. In CO, they were around 4000, and in TN and CA they went for 1000-1800.
The M871 and M872 (3 axle) trailers I've seen have both 12v and 24v light systems.
fasttruck
636
Mesa, AZ
Yes mousekateers the m 127 family and m870,871, 872 etc have both 12 and 24 v plugs but there ends the resemblance. The older trailers have air over hydraulic brakes and three completely separate sets of lights: 12 v service, 24 v service and 24 v black out. New trailers have straight air brakes and 12 v service lights with a set of resistors to cut 24v down to 12, uses same bulbs. 24v lights are provided for black out. Am having a problem matching up resistors for my 871 which are missing and i have a parts book with fsns.
ken
25
Houston Texas
Jasonjc,
Does the TM say why this trailer shouldn't be used with a M52A2 tractor?
Bighurt
46
Minot, ND
From the TM;
Do not tow the M871 or M871A1 with M52, M52A1, or M52A2 truck tractor. The M52 five ton truck tractor’s inherent design capabilities are not compatible with the semitrailer, and if used would result in a serious compromise to the safety of personnel and equipment.
When towing the semitrailer with the M818, the fifth wheel wedges on the M818 are to be in the locked-in (pushed in) mode for highway and secondary road use, and in the locked-out (pulled out) mode for cross country operation.
The M52 can't lock the 4 way hitch like the M818, its the side to side roll that will put the trailer deck into the rear tandems on the tractor.
Bighurt
46
Minot, ND
All steel framed trailers should be routinely inspected for cracks. The DOD just moth balled 200+ super trailers for cracks from the manufacture. We may see these as surplus in the future, depending on what the manufacture does...
If anyone has 325 BF of Purpleheart for their trailer, let me know I'll trade you...
The replacement decking for our 7Q trailers is Teak...
Why these manufactures pick such rare and expensive woods for deck replacement is beyond me...
