Skinny
- 487
- 83
- Portsmouth, NH
Since my M1031 came home and I got it running, the trans has been doing a classic late shift issue. Now that my 6.2 is running good, I've started the diagnosis on it.
First road test, it was shifting at 37mph and 50 mph. I had only 5" of vacuum at the modulator. I fixed some vacuum lines and got a slightly higher number. I then cranked the IP vacuum all the way and got 15" at idle. I figured this was still on the low side but much better than I had before. Roadtested, still the same issue.
Today I ran a straight line from the vacuum pump down to the modulator bypassing all the factory lines and valve. I was getting 23" of vacuum at the modulator. Roadtested, my shift point went down slightly to 32mph and 47mph. This still seems way too high.
Followed the TM and disconnected the down shift plug on the side of the transmission. Roadtested, same as above.
I know the next obvious thing to do is a line pressure test to determine if it's the governor or an internal valvebody issue.
Just for some feedback so far, has anyone had a failed governor? What are you guys experiencing for governor failure (and I don't mean Arnold Schwarzenegger...get to da Choppa)? It seems like most people with this issue have a failed modulator or leaking vacuum line issue. Nothing I read on SS so far has mentioned replacing a governor which leads me to believe they are fairly bulletproof. Other than late shifts, they seem to be consistent, fairly firm, and the fluid looks great. This trans has no lag or delays when putting into gear which makes me think the valvebody and clutches are in great shape...only has 6600 miles on it which I believe. The interior shows no signs of being over 100,000 miles old.
