USMCWARWAGON
- 0
- 0
- Lincolnton, NC
Hey guys, I need some help. Forgive me for not knowing technical terms. I was using my deuce the other day to drag some small pine tree, after I was finished dragging the pines I was backing down my driveway, I pushed in the clutch to take it out of reverse and to put in first gear, I heard a pop (not loud) and the shifter went into the 5th gear position. I tried to take it out of the 5th gear position and it wouldn't budge. No matter what I do, I couldn't get it to move. I pulled the top cover off of the transmission. The gears look good (look almost new). What I did notice is that the shifter (shift forks) are in a bind somehow. Shifter is stuck in 5th gear position. The shift forks look good (not bent or broken), the rods that the forks are attached to look good also. I noticed that the guide plate (plate that has two springs and the shifter appears to ride in) has been broken in a spot. Another problem that I noticed was that the transmission was dangerously low in fluid. With the top plate off the transmission, I started up the deuce and let up on the clutch and it bogs down and dies (makes me think that the trans is still in 5th gear). I am able to move the most rear gear forward and let off the clutch (while engine is running) and it goes into neutral. I'm not sure if I can replace the rods that the shift forks are attached to, and the plate with the two springs, or if I need to replace the whole transmission.
I will post pictures this weekend.
Sorry I couldn't explain it better.
