Troubleshooting M101A2 Brakes
RJM27
26
Burdett NY
Followed all directions in TM on bleeding brake system. When I go to pump the break away lever it is loose, can feel the spring move around for the first 2 notches on leaf spring. I am able to get good pressure on the break away lever except for the begining, also no air all brake fluild. Any thoughts on what needs to be replaced. The Lunette has good travel and back pressure from the brake fluid as well. I have another trailer that the brakes work great on and I don't have that freeplay in the beginig of the break away lever.?????????? Is this about the shock or the spring hardware????
glcaines
2,548
Hiawassee, Georgia
I just bled the brakes on my M116A2 trailer, which is identical with the M101A2 surge brakes. I know the TM says to pump the lever to bleed the brakes. I found that holding the spring up from the lever and moving the lunette in and out worked much better. I had to replace brake lines, so mine was completely dry when I started bleeding. Are you sure your lunette is not pushed back and this may be causing the slack in the break-away lever? Try pulling the lunette forward, maybe even prying it forward.
1,176
Guessing this is the trailer that you transported upsidedown?
RJM27
26
Burdett NY
No this trailer was on the ground, also have the same problem with one other. The other 2- work fine. I must be missing something simple (I always do). I did move the lunette all the way forward while bleeding. Thanks for the info.
Bob.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
This might be bad advise but, when I bled mine, I put a pipe wrench on the swing arms that connect the master cyl. That got them bled quick and easy.
glcaines
2,548
Hiawassee, Georgia
That's probably not bad advice. That would most likely be a lot easier than moving the lunette back and forth by hand like I did. One note: Moving the lunette got much easier after several cycles and I did lubricate prior.
