Truck without front drive shaft and hubs
jimm1009
71
Louisville, KY
I took my front driveshaft off yesterday due to the non-airshift transfercase, removed the front drive hubs, removed the left forward axle shaft, and temporarily installed front drive hub on rear.
Drove it about a mile down the paved road and back for a test.
What a difference in handling! I sure would like to be able to afford the axle disconnect kit and the locking front hubs!
The steering wheel was about 30% easier to turn while moving and the turning radius "seemed" sharper too. Did not have a paved area big enough to do a full test though.
Well back to putting the axle shaft in and the drive hubs back on for now.
Can I leave my front driveshaft off or is this a bad thing to do with the old style transfer case installed (non air-shift)?
Jim
jimm1009@yahoo.com
FSBruva
Marietta, GA
By "Front drive hubs" do you mean the splined drive flanges? I would imagine that removing a hub would make driving pretty difficult/slow?
Matt
m-35tom
222
eldersburg maryland
you may notice some improved steering with locking hubs. you would have to leave the driveshaft out to improve fuel consumption, but i doubt you could measure the savings. no problem for the transfer but a pita if you wanted front drive.
FSB, "removing a hub would make driving pretty difficult/slow?" why??
steelsoldiers
4,014
Charleston, WV
Re: RE: Truck without front drive shaft and hubs
I think Matt was being very literal in that removing the hub would make it impossible to mount the wheel and make for very slow going.
jimm1009
71
Louisville, KY
Driving without a hub would be very sloooowwwww indeed since the wheel would not have stayed with the truck either.
Sorry, I meant to say "drive hub" or "drive flange".
It sure does feel better steering around tight turns without the front end turning and the forward rear axle disconnected.
I put all the stuff back as Uncle Sam had it except for the front drive shaft.
I don't have any "loose stuff" to drive it in right now and three of the nuts for
the driveshaft attachment bolts are no longer hex shaped.
I will be installing all new nuts when I go back with it.
Easy to find in the aviation industry where I reside.
Jim
