jayjaytocool
- 0
- 0
- rochester ny
does anyone know to turn the fuel up on Cummins 6CTA8.3 im assuming cam plate adjustment. do we needparts if so what parts and where?
thanks
thanks
Unfortunately, the transmission is almost at its limit already. I have seen anywhere from 250 to 270 HP as the max HP limit. The transfer case will be OK so long as you don't try low-range and reverse at the same time. That tends to crack the case.what is the limit on drive train hp? I see it's not hard to go to 400hp id would put on an air to air cooler if i went that far. is this safe for the drive line?
