CCATLETT1984
- 5
- 0
- Saint Clair Shores, MI
Re: RE: Re: RE: Re: RE: Twin Turbo Deuce
I know that my 6.2L runs 21.5:1
and the 6.5TD was dropped to 19.5:1 (to allow for more boost)
What compression ratio does the multi run?OPCOM said:I may be wrong, but I feel like the stock setup only "comes into its own" near the high end of the range at WOT from 2000-2500RPM. But I have never turned the fuel up enough to produce black smoke either. I don't get smoke at all in fact. In speaking with Memphis Equipment co. they advised me that making smoke for any length of time other than brief accelerations is asking for trouble. The deuce already has an unusually high compression ratio compared to regular diesels so pushing it real hard may not be such a good idea, especially if you have the old style head gaskets. I am aso concerned that if I turn up the fuel too much and lay into it at 1500RPM, I could bend a rod or something? Then there are mountains to be climbed..
Shooting soot all the way up the mountain would seem to be asking for pyro redline or worse. Having been a bit jealous of the black smoke from other people's deuces, I'd appreciate Mr. Waller's comments on this.
