aemarc
- 0
- 0
- Airville Pa.
I Have a 1962 unimog 404.1 that leaks gear oil from the left front hub drive assembly. The seal in question is the one where the shaft goes into the hub drive. Does anybody know if you can change that seal without pulling the entire hub drive apart like it shows in the shop manual? Can it be pulled off as a complete assembly to change that seal? Also does anybody know the part number for the seal in question? Thanks!
