rolling18
- 77
- 28
- Portland, OR
Good day!
I recently upgraded my home waist motor oil "station" by adding a 50 gal. cone supply/ mixing tank, 115v ac pump, large filter housing w/ gauge staged down to 1 micron!
With this setup I can directly fill the deuce tank or a holding tank.
It is very easy to fill a custom blend in the supply tank, it all goes through a one time pass and ready fuel from the filter housing.
its very simple and works well so far with a decent flow rate even at 1 micron due to the very large filter.
I have future plans to upgrade even further by swapping in the 24v dc military fuel pump. to power in the field.
using camlocks to swap hoses and pumps.
big white tank is obviously the cone mixing/ supply tank.
Tall green one is Filter housing
Blue 115 AC pump in middle.
all connected by 1" tubing (may be upgraded to 2" camlocks and Military 24 VDC pump
the whole thing is mounted to a pallet for portability, could be used in the truck if needed
