MatthewH
- 2
- 18
- Boyne City Mi
So after hoping to get by with just bolting the disc brakes on and repacking the wheel bearings, I found the pass side needed new kingpins, as the tire had a goofy wear pattern to it, and the lower kingpin is loose.
After reading the TM, it calls out for a brass/bronze upper cone, and a lower bearing, however, I remember reading somehwere about subsituting a bearing for the bronze cone.
I have searched, but found only mention of this, no part numbers for the bearing or race. Would it be the same as the lower bearing setup?
Matt
Matt
