US6x4
- 2,360
- 113
- Wenatchee, WA
I picked up a combination hex/square hole socket and they claim you only need this one socket instead of two, however if I want to remove just the hex nut on the rear without engaging the thimble this socket will only cover about 3/16" depth of the hex nut. I'm worried about rounding off my lug nuts. Is this intended to remove the lug nut and thimble together at the same time? I'm thinking that this would work well for the front lug nuts and the rear thimbles, but I might need a separate standard hex socket for the rear lug nuts.
Does anyone else have experience with this type of tool?
