lurkMcGurk
- 17
- 8
- Bangor,Maine
I'm not including pictures in here as even in a self deprecating manner its almost TOO ridiculous. BUT I have since used the "DEADLY" method/maneuver to get out of two other mud hole messes completely of my own doing and since FLU farm didn't beat me to it I'm making an acronym!!!
D-driving
E-extraction
A-and
D-dangerous
L-loader
Y-yank
I do want to share some observations though as others here may not have my level of Cat Like agility I can wholeheartedly assure you before attempting this you should think it through as each situation will be different. Caveat Emptor
Some general considerations with the SEE for me once stuck and attempting extraction are the following.
1. who is watching me doing this? Important as people love to give advice that don't know $%#^ all, and its distracting!!
2. how stuck are you and on what. I'm not to worried about mud but rocks can scrape and tear so just look around a bit.
3. are there big trees around to tie off to? WELL ROOTED trees (ask me how I know) ROPS are our friends
4. tie off to the rear of the bucket and since your only using one (rope, set of jumper cables, vines) tied to the Dipper lever keep the boom high and set the tension so you can get the most travel in the dippers most powerful sweet spot.
5. be aware of the angle you are pulling out and where it will pull the rest of the machine because once you get moving you want to get all the way out not hung up. part of this is where are your stabilizers traveling, I left one of mine out as the lean was a bit much during one extraction and I did not want to tip. also if the bucket drags or the pintle hits a rock you stop moving!
6. Sounds dumb but if you have the door feature that just opens sometimes don't lean against it or use the belt. your hands will be busy
JUST prior to doing the MANUEVER
When you are set up in the drivers seat with door closed string the dipper connected rope through the window, set 4x4, clutch in, pto on, lift loader low as possible choose gears and get up a decent rev but nothing crazy, let clutch out and pull dipper. I encountered a stall on two occasions here and wonder if that was because the power gets robbed quickly by the hoe and drivetrain acting in tandem so I used intermittent pulls on the dipper.
It seems a bit crazy, oddly enough its not mentioned in the TMs or PM's but it has worked for me like I said. I will not be venturing into this particular muddy area till July ever again but the "DEADLY" method does work and maybe should be noted somewhere in this forum (for strictly academic reasons). A lot going on at once but if you are working alone and dislike most "sources" of advice available to you and have a keen interest in not wasting more time than necessary AND it seems to rain every day since you got stuck etc etc etc.. Maybe reference the above and certainly be as safe as possible or will me your estates and crazy machinery Beforehand
I recently got two 25' double ply 4 inch 40K lbs rated straps and two very large U bolts, they are great. Cheers
D-driving
E-extraction
A-and
D-dangerous
L-loader
Y-yank
