Tlauden
- 3
- 18
- Halifax Pennsylvania
Ya I relize that the setup in the vid wouldn't work using a deuce but I might give it a shot using my pickup.
Ya, I figured cost mite be an issue, I was going to start asking around to find a worthy tank, I figure a old large propane or compressor tank could withstand a vacuum, pulling vacuum will be the kicker, need to find a way to do it cheaply and make it worth it, then just some hoses/fittings and someone who will weld. In the end I guess cost depends on how many free goodies people are willing to part with.I just don't think the vacuum idea will work without significant cost and expense. Sure you COULD hook up a compressor to run a vacuum pump... but why not just pressurize the oil to 10-14psi?
Are your hoses and receptacle tank sealed to withstand that much negative pressure? Remember you cannot put stuff through a vacuum pump so you have to put a vacuum on a tank and let atmospheric pressure on the other end push it to you.
