Kellyboy
- 0
- 6
- Milton, VT
So while driving my panty melter to work yesterday if I let off the throttle to coast when I got back on it it had no response for like 3 seconds then bang it would kick back on. It happened every time I let off. If I rolled to a stop it would idle fine and take off like normal. After work I popped the hood and found the vacuume line from the vacuume pump was cracked real bad where it hooked up to the modulator on the IP. I cut a couple inches off of it and hooked it back up. So far 3 one way trips to and from work have been flawless. My question is would a vac leak cause a hesitation on the IP or was this just a fluke fix that I can expect to return? Not really sure if the mod does anything to the IP or just controls the tranny.
thanks.
thanks.
