Valve next to radiator
ida34
33
Dexter, MI
If it is brass then it is probably the oil sampling valve. Not all of them had it. It should connect to the oil cooler line.
Jeeperjoe
Ramsey, MN
Anyone know the nsn or even better a civy replacement part number mine leaks maybe a class 1 leak but a leak none the less...
Sorry to rez a dead post but hey that's what search is for
Mainsail
1,624
Puget Sound, WA
I bought a couple antenna brackets from a local guy that was parting out his burned up M1009. He said his oil sampling line suddenly burst and sprayed oil onto the exhaust manifold, creating a fire that destroyed his vehicle.
He advised me to remove mine, which I didn't do for a couple years. It's off now; I just pulled the adapter out of the cooler line and reconnected the two ends.
Jeeperjoe
Ramsey, MN
Interesting so his engine built enough pressure to blow a steel line hmm
Mainsail
1,624
Puget Sound, WA
By line I mean the system of lines, valves, adapter, and cap that comprises the assembly. To believe the engine "built up" enough pressure to blow open a steel line would be uh... shall we say, silly. It didn't happen to me; I merely reported what I was told by a (former) M1009 owner.
Jeeperjoe
Ramsey, MN
Fair enough... I kinda like the ability to sample oil if I want to have it tested not sure if i would actually use it or not though, something to consider
