HelluvaEngineer
- 82
- 28
- Atlanta, GA
I just went out in the "back 40" to try to start my m1009. It's 24v w./ doghead relay.
I got the glow plug thunk, then turned the key, solid starter relay thunk, but the starter wouldn't spin at all. We've had a long hot summer and it's been cooking some of my batteries, so I suspect that's the issue. I can charge and load test them obviously and I will but I'm curious about something.
My multimeter says the two batteries in series are at 24.2 - 24.4 volts, which definitely sounds low but could be worse. However I noticed that at the relay it was only putting out about 19.4 volts to the starter solenoid. That's very low. Anyone know why there would be such a voltage drop and also if that's theoretically enough to trigger the solenoid and at least get the motor to spin slowly?
Thanks!
Thanks!
