- 1,680
- 2,168
- 113
- Rosamond, CA
I am not confused... Too, Just not the boots, hands and eyes on the problem. Thumb back thru this / these threads a couple years might help. History seem to repeat itself on a HumV, LOLI’m definitely confused on the ground issue too. Was sitting here reading through troubleshooting (no help) and then the wiring harness picture. Like you say, would seem all grounds would tie together. And, yes, that harness looks to be in pristine condition.
Looks like a couple chassis grounds over on corner lights I can touch up. I’ve already run all the factory grounds from engine rear (as well as adding the 5-point supplemental ground harness from the drivers rear engine head bolt).
But, tomorrow I’ll swap the working headlight for the bad side and see what I get.
Thanks for the input. Will advise…
Remote control robot driven over the interweb, CAMO
