Crash_AF
- 7
- 38
- Colorado Springs, CO
Where are you checking for voltage for the glow plugs? Did you check all 8 plugs to make sure they are all working?
And no, there are no safety switches on a CUCV. If the pink wire has 12V and the solenoid in the pump clicks when power is applied and removed, then it should be getting fuel unless there is a problem.
When you cracked the lines to bleed them, how much fuel came out? Was it a lot or just a little?
If you do decide to cheat with ether, disconnect the light blue wire from the glow plugs to disable them. Hot glow plugs + ether = very bad things.
I'm going to lean towards the glow plugs not functioning and not getting the cylinders hot enough to fire.
Later,
Joe
Later,
Joe
