US6x4
- 2,360
- 113
- Wenatchee, WA
The title describes what I'm seeing which is a new behavior ever since I replaced the voltage regulator. The needle bounces back and forth from far left up to actual engine temp with the engine/alternator running. When I shut off the engine but keep the master switch on the temp gauge is steady on the actual temp. This did not happen before the alternator fix and none of the other electric gauges are doing this.
Has anyone else seen this behavior?
