Last week, I found fluid in the engine valley. We've had a lot of rain. The fluid was clear and odorless but seemed viscous for just water.
I mopped up all the fluid. With the hood raised and doghouse removed, I idled the engine in the driveway and carefully watched the IP. No drips for 15 minutes. Everything bone dry.
I took the truck for a 40 minute drive and found a bit of fluid in the valley down by the IP. It seems to be fuel.
If the leak only presents itself under additional pressure from driving, what should I be looking at? Is it just a loose fitting?
I understand that a crow foot wrench is best to snug down fittings on the IP. What size, and how long of an extension is needed?
Thanks.
Thanks.
