- 1,960
- 225
- 63
- Arizona
They are absolutely heavy, that is for sure.
I recently bought a rebuilt transfer case mounted in the lower half of a shipping can for my M813. In total, it weighed 1,000 lbs. I think Wes said a T138 transfer by itself weighs 644 lbs. A friend told me the shipping can weighs around 300 lbs.I brought an air shift transfer case down to my shop today and threw it on the scale...465 lbs! It still had the parking brake assembly and drum on as well as the cross-member and gear oil. I knew they were heavy but wouldn't have guessed that much.
28 lbs, I think. No more than 30.How much does the 60-amp alternator weigh?
Straddle brake drum and use both hands to slide it off and lift it - one hand on the hub, one gripping the edge of the brake drum. Set it on a couple wood boards in front of the spindle so you keep it out of the dirt while you go get something to safely move the hub-drum assembly.Pulling the drum assemblies is a common task and there are lots of ways to reduce the risk of injury. Please post your suggestions/recommendations.
That must be with the hub still attached?Mine weighed just under 78 pounds each.
No. I weighed one of the rear drums before I put the last one on yesterday.That must be with the hub still attached?
And it looks like this? That's odd because I have 2 scales at work and they both say 50.No. I weighed one of the rear drums before I put the last one on yesterday.
