spankybear
- 926
- 93
- WA
Check the fluids and all looks good. The trans motor oil smells fresh with no burn small. The engine looks very unmolested almost looks new
They didn't cut the wires when the pulled the voltage gauge They did however damage a couple of rocker switches. Just need to fine a source for SWF compatible switches.
Looks like all of the relays are there and correct. The circuit bearers are all there. There are a few that look suspect. It looks like ATO fuses will fit in a pinch.
I am confident she will start when I get some batteries.
Some of the bad... Roof leaks and has rust.
Drivers side floor board looks to have a fair amount of rust.
OCD stuff...
The side view mirrors don't match.
Missing and fades data labels.
Leaks air.
Spare tire worn more than I would like plus it doesn't match (Major OCD )
I am going to start a list of parts I need here...
Volt Gauge
Batteries
Hazard rocker switch
Parts I will want:
Passenger side seat belt.
Tailgate? They took it off for whatever reason
Gunners seat
Door Pull/handle (Grab handle to close door)
Drivers side floor mat
Board ladder
Grill... From talking to some folks I guess the consensus is that someone followed a M1 too close melting it. I maybe able to fix? Will have to iv it a shot.
There's a little black plastic electrical box under the left side dash that looks that is should have a cover. I have yet to identified what it is.
Not too much else to say on a rainy Sunday
OCD stuff...
Leaks air.
Volt Gauge
Batteries
Parts I will want:
Gunners seat
Board ladder
