![IMG_20190928_174444.jpg IMG_20190928_174444.jpg](https://www.steelsoldiers.com/data/attachments/534/534048-afc5527a5d343f123475b9839528af3e.jpg)
![IMG_20190928_174453.jpg IMG_20190928_174453.jpg](https://www.steelsoldiers.com/data/attachments/534/534050-9b2f49d26e5c978f153e21d26235a8e3.jpg)
![IMG_20190928_174504.jpg IMG_20190928_174504.jpg](https://www.steelsoldiers.com/data/attachments/534/534052-97b4c19720bdf28f8b8a3416751b1a0b.jpg)
![IMG_20191013_160427.jpg IMG_20191013_160427.jpg](https://www.steelsoldiers.com/data/attachments/535/535545-f786326a283267e7df1262cb3c47af1c.jpg)
![IMG_20191013_160442.jpg IMG_20191013_160442.jpg](https://www.steelsoldiers.com/data/attachments/535/535546-232639cfa3aee6fcaada075ea2fb3a92.jpg)
![IMG_20191014_194829.jpg IMG_20191014_194829.jpg](https://www.steelsoldiers.com/data/attachments/535/535547-16718fa28d75c6c4bdacb294579293e8.jpg)
not in any particular order, but picked up a mostly stripped trailer.
Had to replace one section of brake line, then flushed the system using a mightyvac.
Finished stripping it down, cleaned up the rust spots.
Primed and painted it yesterday.
I do need to find a new vent cap for the brake master cylinder, but other than that looking pretty good.
Next step will be to build some type of deck for it, since It no longer has the 33kw gen and 8 ton ECU on it. I'm thinking 2"x1" rectangular tube steel with 11 gauge flat steel decking. The 2" of tubing will allow the deck to sit same height or above the angle iron piece across the front, and also clear the fuel tank outlet on top so if I want to put the tank back in I can actually use it as an auxiliary for a smaller gen.
For right now my thoughts are having it as a flatbed utility trailer, along with some removable sides.
Might also make it so my MEP802A and the Nordicair 3 ton ECU mount onto it, offset to the left side so my temper tent can be transported on the right side. The load would all be between the fenders so shouldn't be an issue with the gen to one side.
Maybe make a set of bows and a canvas top for it while I'm at it.
(if I do use it with the 802A and have the 55 gallon tank still installed I'll easily have over 100 hours of running at full load without having to refuel, so that's a bonus)
