Ok, so as far as I can tell this is a special fuel cap and copper tube set which will connect to the auxiliary fuel hose on my 803A and similar gensets.
My questions are:
1- What does the cap fit?
2- What is the fitting size/type?
I am thinking that I will get another fitting like this and tap the tube and fitting into a 55 gallon drum cap so I can use it to draw fuel from my 55 gal storage drums during extended power outages. I also need to make a rain proof vent in the second drum cap so it does not cause a vacuum issue when pumping the fuel.
