What does this do? (Water Separator internals)
Russ Knight
1,054
Perry, FL
Other than require constant disassembly and cleaning. I'm sure it's a debris trap, but what is the plunger thing for? Vent moisture?
edited for clarity
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Or your governor is having issues causing your compressor to run all the time and cause excess moisture and not cycle off.
Sent from my SM-G935P using Tapatalk
Russ Knight
1,054
Perry, FL
It's never had any moisture. Just debris, small flecks of rust, grit, etc. Starts leaking air. Can I just cap the bottom port off?
simp5782
9,339
Mason, TN
No. You need to clean and drain your wet tank out. It may be full of rust
