- 649
- 85
- 43
- Broad Run VA
Both trucks have batteries under seat. Both have gone through a rebuild
The truck in your avatar has a battery relocation box for the passenger side. The batteries would normally be relocated there when the box and the rest of relocation kit is installed. Your new truck has the standard box configuration for batteries under the seat as it was originally issued.Both trucks have batteries under seat. Both have gone through a rebuild
Mounted 16.00r20 XZL on my M543A2.
Sent from my SM-S820L using Tapatalk
Did you chop up an old slave cable for that?Got my new charger wired to the slave plug. Very handy.
They have an adapter for that. I think i have a few. There are some on that shelf inside the door at memphis equipmentHey Big Block, I really like your charger adapter. I was thinking of something along the same lines, but my truck has the older slave "two prong" plug.
Ratchet strap. Its easiest that when you pull it out of the other tire to compress it down so its smushed being pulled out. The same way you would do a runflat insert.Does anyone have any suggestions for how to get the bead lock in a new tire? Been fighting the last two tires, still got 5 more to go and was hoping someone knew how to do this that wasn’t a real PITA.
