From Jane's...
DS2, ABC-M11 portable decontaminating apparatus (United States) - Jane's Nuclear, Biological And Chemical Defence
The one in WARWAGS M1028...DS2, ABC-M11 portable decontaminating apparatus (United States), Decontamination
Description
The DS2 (Decontamination Solution), ABC-M11 portable decontaminating apparatus is carried on a rack on nearly all US-produced military vehicles and is intended for the decontamination of vehicles or crew-served weapons. Normally, the equipment is issued with the nitrogen pressure cartridge already filled and in place, but the container has to be filled with DS2 decontaminating agent before the equipment is ready for use. When used, the handle safety-pin seal wire is removed, and the handle is lifted to puncture the pressure can. A thumb lever then controls the spray, which has an optimum range of about 2 m. The equipment will cover approximately 42 m2.The standard M11 has a filled volume of 1.26 litres. Also available are the M11 Stretch version, with a filled volume of 1.5 litres, and the M11 Super Stretch version, holding 2.5 litres. At present only the M11 and M11 Super Stretch versions and listed as available.Decontaminating Solution 2 (DS2) is flammable, highly corrosive and irritating to the skin. DS2 is 70 per cent diethylenetriamine, 28 per cent ethylene glycol monomethyl ether and 2 per cent sodium hydroxide.Due to the toxic, corrosive and flammability hazards of the DS2 decontaminant, the M11 and M13 decontaminating apparatuses are likely to be replaced with the M100 Sorbent Decontamination System (SDS). The M100 SDS is both non-toxic and non-corrosive. For more information on the M100 SDS please see the relevant entry in this section.Also available is the Model M11 A/G dry sorbent dispenser.
