jesusgatos
- 28
- 38
- on the road - in CA right now
either/both
If you have 6 inches, then 395's will fit. You will have 3-4 inches left. The stock tires are 40" in diameter and the 395's are 46". By far the best looking size for bobbed and/or singled deuces IMO.yeah those will never fit. i need tires around 41-43" overall diameter
With my bob job i only have about maybe six inches between the gas tank and front of the tire.
395's will fit, i have seen them on quite a few trucks, and they are as big as you can go without a lift and axle relocationill have to measure to see, but with tires i need to have half the total height gain in a straight line towards the tank right?
Correct. If you have 6" now from your stock 40" tire to the tank, the 46" tire will give you 3" left. What kind of bed is on the truck? Ours use the M105 bed and there is 13" of room stock, so 10" with 395'sill have to measure to see, but with tires i need to have half the total height gain in a straight line towards the tank right?
Yes.what about Michelin G-20 Pilote XC 15.5/80R20's? will they fit a deuce?
Yep, they're 46" too.Yes.
its the standard m105 setup like everyone has. But mine is different than most.
