what to look for in a m816??
jayjetseck
manchester , pa
found a 1980 am general m816 for 6000 .. she has 19000 miles and looks good in pics!! never owned a wrecker but looking for advice on what to look for in trouble areas ??? everything is to work with no leaks but well see !!from what ive seen this is a very good price and only 30 miles from home wiyh clean title. so any suggestions would be gratly appreciated!!
doghead
4 Star General /Moderator
1,172
NY
Send the info to me, If you don't buy it!:roll:
area52
San Bernardino CA
Yea, if it runs or could possibly run, BUY IT NOW!! $6000 is a very good deal for a wrecker.
Does it come with any goodies i.e. towbar, slave cable, chains etc.?
take some pics and post em up!!:p
bigmike
354
Dixon CA.
Make sure the boom goes all the way in and out. Sometimes, they extend the boom and try to pick up something too heavy and damage the boom. That might make it a deal breaker. Also see if you can see it swivel. Make sure that mechanism looks and works well. Otherwise, engines, trans, etc are easy fixes. sounds like a great deal. I wish I could run across one for that price.
best of luck and post some pics soon.
jayjetseck
manchester , pa
went down to do final inspection of wrecker and wow i think i scored big!!! 16ooo miles immaculate paint front winch, tow bars , not one hydraulic leak even has all stickers inside and out in perfect shape.. looks like it was maybe used a dozen times .. all the mechanics work flawless... only issue i found is that its missing the cable ends for the rear drag winch., but it still spool in and out,also needs some tires from sitting in the garage for last 5 years .. the owner said it took it out monthly to strech its legs and always operated the attachment to keep lubed.. he thinks there spades in the shop somewhere along with some other parts he even has extre boom slides ( jib) ,not sure exact name but the main arm .. total price 6500 because he put 4 new batteries in..its about 1 hr away going to bring home tuesday so there be more pics then.. i never find deals like this so hope it turns out good !!!!
doghead
1,172
NY
Sounds like you did score big! Good For you! Hope you enjoy it!
I want to see pictures!:wink:
jayjetseck
manchester , pa
dont think ill be able to sleep till she home!! planning on hanging a pinchota off the hook for my daughters birthday this weekend!!!that will be some good pics !!this is my second 5 ton my first is a m813a1 then this , they are much more addictive than any of the 5 dueces ive had..
