What to look for when previewing MEP-002A
leedawg
11
Napa / CA
Looks great, lets see some after pics now that you have the batts installed and everything. Do you mind taking one picture close up where the oil filter housing is. I just got one of these myself and the cover on the starter lock out switch is missing and the wires to it are cut so im pretty sure im going to be into a bit of a project getting some of the wiring fixed on mine. Thanks
Lee
Jimc
9
Mullica, nj
thats fantastic. good for you!! seems like another good thing to do to insure reliability is to go over all the wire connections and grounds to make sure everything is clean and making good contact. seems like alot of issues lately can be avoided by doing that. alot of components on these generators ground through the case and the mounting bolts make the connection which like on mine every nut bolt and washer were just about completely rusted away.
