What's this for? Ladder
Dodge man
Fl
Does anyone know what the ladder in the (hopefully!) attached photos is for? It has four steps and is just over 5 foot tall when collapsed and appears to be designed to attach to a point approximately 46" above the ground. As you can see in the photos it's too tall for my M37 and has the wrong kind of hooks. The legs telescope out the bottom and it appears that they can be extended up to ~29 inches but there's no step on the bottom extension so the first step might be a doozy! It has spring loaded clips to hold the extension in but I don't see any way to lock them in the extended position. The bottoms on the ladder are round. The legs of the ladder are ~ 1 1/4" w x 5" tall and the overall width is 14 3/4". It has flat j shaped hooks so it looks like it's designed to hook into holes or slots. There are also two spring loaded pull pins on the back of the legs near the bottom. I expect that they're used to lock it into a storage rack. Most of the ladder is made on aluminium but the extensions are made of steel. The steps are made out of stamped aluminium and have expanded metal welded to the top on them.
SCSG-G4
PSVB 3003
3,324
Lexington, South Carolina
Dodge man,
When you want to attach a picture, first make sure it is in JPG format, and is no bigger than 800 x 600 (or 600 x 800) pixels, then click where it says 'manage attachments'. Click on the 'browse' to find the location on your computer where the picture is. Do for each picture up to 10, then click on "UPLOAD" and wait for it to finish, then close the extra window. You should then see the names of the attachment(s) below your posting. THEN, post your message. Try it, you will be pleased with the results!
Dodge man
Fl
I might need a shop van ladder. Where in FL are you?
(located in Palm Bay)
LOL! Believe it or not, I just bought this in Melbourne!* I'm in Orlando. I bought it in hopes of using it with an M-37 but it's too tall and the hooks are completely wrong and I've already found a proper ladder (I think!). I'll swap it for something I can use.
* the next town north of lavarok for the ones of you that don't know.
