Barrman
- 1,771
- 113
- Giddings, Texas
Thanks for posting the pictures Randy. I read through all the above post thinking of how to describe that the u-joint couldn't have moved out and the entire assembly still be on the truck. Your picture did it.
While thinking about causes, what about "wind up?" Those of you with air shift don't have to worry about it, but the rest of us know if the truck is in 1st and it rolls back just a little with the clutch in, everything gets bound up. If you are on pavement, it doesn't get better. Then, if you push or pull the truck around, it will get really, really bad. Eventually so bad that the truck won't move. I can see GL pushing the truck around and with no thought to that. It could lead to the end of the axle getting broken. If the break is at an angle, the angle could act like a ramp and push the stub out the end of the flange.
Another long shot idea is grease or gear oil. Say soldier C was told to put the hub flange back on the last time it was apart. He filled it full of grease or gear oil and used the bolts to get it all the way on. The truck doesn't get driven much if at all after that. SETOYOTA gets in, drive it around and the axle shaft pushed in all the way to the inner seal on the axle tube "self clearances" itself back out. The grease pushes the end off the flange as a result.
Just random ideas. Let us know what you find.
