When the spare goes too...
Fleg
Rio Rancho, NM
That sound non-typical and unfortunate. Do you remember what brand the bag was? What condition was the bag in? You sure it was not leaking? I ask because I have seen them work in person and there are dozens and dozens of youtube videos of people successfully using them.
Well, I'm not going to bore you with a bunch of Youtube videos. If you watch it on Youtube then it must be true!
The bag was new, in box, Not leaking, and not lifting. They are worthless and a gimmick.
Mohawk Dave
14
CA
Hey guys,
As some of you know, we race desert and then do many trails in our 4x4s. We carry rawhides for punctures, I carry the large bottle of slime in my tool box, and then of course starting fluid. I did not see any one mention the starting fluid yet, but when a bead comes off, we spray a couple seconds in it then add flame. We put 37s on rims regularly like that. (And no, there is not enough combustion to blow the tire or blow it off the bead)
On board air is listed by all the other guys before my post. So, really which one do you like and want to carry? But to bead, we use starting fluid.
Best wishes,
Dave
edpdx
75
Oregon
Thanks Mohawk Dave, this is just the reason why all questions should be tolerated even if asked before. Starting Fluid? :shock: you won't find this fix in the TM9.
Fleg
Rio Rancho, NM
I've never had a problem seating a bead with a York powered system. Haven't got to try it yet using the electric compressor but I'm guessing it's going to be a little harder.
toddm
Pewaukee WI
I run singles on my M35 and I carry the standard mounted spare tire and two others in the bed.Just in case and I built a small lift to hep loading and unloading those heavy suckers out of the bed.
edpdx
75
Oregon
toddm, nice lift, yeah that has got to be a big help lifting those muthas into the bed. Good Call.
