- 6,071
- 4,442
- 113
So, looking at this 5pin plug...
The bottom smaller pin is ground. The one at 1100 is neutral, and the other three are 120v each voltage potential from neutral.
If I take a 3 wire cable and grab B C and Neutral, and wire a 50amp 240v female on one end, and a 5pin male on the other but connected using only B C and N, now I have a plug that will plug into the genset, and will allow my single phase 240v welder to plug in... and as I understand it, what I'll have is 208V single phase.
My welder shouldn't care. It'll run on 120v with a reduced duty cycle, or on 240v with an enhanced duty cycle. 208v should be close enough.
What am I doing that's stupid or dangerous?
